Hi,
I have a 2003 Honda 50 and have some concerns over the gear selection.
Sifting into forward is fine and smooth but when shifting into reverse it always crunches before engaging.
There are no problems with it jumping out of gear in forward or reverse.
I've checked the remote cable adjustment and it seems fine.
According to the Honda tacho the idle speed is just under 1000rpm (manual specifies 900-1000)
When I select a gear I make sure that the boat is stationary, the revs have dropped back down to idle and I move the lever quickly and positively.
Could wear on the dogs cause them to grind over each other more than usual before engaging???
Any pointers would be much appreciated.
