Honda 9.9 2008 prop choice?
Lebasque
I still have the factory honda prop on my motor.
Material: Aluminum
Diameter: 9 - 1/4?
Pitch: 8?
Blades: 4
I dammaged the prop with scratches (don;t like the look).
I was thinking on putting a new prop.
Can I go for a 3 blades? or should it stay with 4 blades?
I use the motor to troll (bay and ocean).
What about the pitch? is 8" good?
Alu or stanlesssteel?
Just curious,
Thank you
steelespike
Re: Honda 9.9 2008 prop choice?
Without a lot more info can't be much help.Is this a kicker on a larger boat or on
a small fishing boat? Can't tell you much about the pitch without a max rpm at wot. It is about in the middle of the chart with 3 sizes smaller and 4 bigger.A 4 blade will give you better control especially if on a larger boat.
Lebasque
The boat is an Arima 19SR.(2008)
Main motor is a honda 115.
Kicker is a honda 9.9
Thanks
Jm
RicMic
I'd stay with the same size prop for your use, you won't really gain much with SS.
