Honda 9.9 hp outboard bogs down want won't start
Perchup65
When I first go to us my motor it runs good, it will start up on the first pull and run for a good half hour then it slows down and shuts off, then it won't start, ill leave it alone for awhile and it will start again and run for 10 min but then stops and won't run again, I cleaned the spark plugs, cleaned the carb, changed the tank and hose, I don't understand what the issue is, if anyone can help I'd really appreciate it , thanks kyle
MattFL
Re: Honda 9.9 hp outboard bogs down want won't start
When it starts to bog, what happens if you pump the fuel bulb?
Sea Rider
It could be a carb diaphragm failure or electrical component intermitent overheating related issue...
Happy Boating
