Honda and Suzuki prop
drfish18
What is the proper size prop for a 90hp Honda or Suzuki engine? Can a evinrude prop be substituted?
Silvertip
Re: Honda and Suzuki prop
Don't understand your question. Are you asking if a Suzuki or Evinrude prop will physically fit on your Honda? Or are you wondering what diameter and pitch you need (wherever the prop comes from) for your Honda. While I'm not going to research the first scenario -- would say NO it won't fit. While it may fit the splines, the hub/gearcase interface may not be right and probably would not be. As for what diameter and pitch you need, we can't help because there is no such thing as a "standard" prop. The engine didn't even ship with one since Honda has no idea whether the engine will be installed on a barge, work boat, fast hull, pontoon, etc. all of which take a different prop. Look at your prop and get the numbers off of it.
