Honda BF25
Phil Lemoine
Hey, a friend has a early 2000's honda 25 horse fourstroke and he wants to put electric start on it. i am just wondering if anyone knows if the BF35 starter will fit his BF25? i cant seem to find a starter for the 25 horse, i think the block is the same as the 35 horse and theres a lot of starters on ebay for that motor.
any help would be great.
hondon
Re: Honda BF25
You will need much more than just the starter and there is no kit available for this conversion that I am aware of.
Phil Lemoine
Re: Honda BF25
theres not much more then the starter that you will need. all i was going to use is a push button ignition switch, a 12 volt solenoid and then the flywheel.
the flywheel and the starter can be costly going through honda though. i think if i get an aftermarket starter i would then just order the flywheel from honda. but for both the flywheel and starter from honda is almost $600
