honda BF50 year 2000 model rpm tach idle problem
tengals123
ok so it's my first ever 4 stroke
engine runs fine, idels fine, but just hooked up faria tach and reads 2100rpm at idle, turn the idle screw out and drops to 1900 and below and shudders and cuts out, viabrates alot
the setting on the tach is set to setting 2 - which is 6 pole 3 pulse, IS ITS CORRECT??
any ideas?
Nucdaddy
Re: honda BF50 year 2000 model rpm tach idle problem
any ideas?
Not sure if you checked the web site for Faria but this may help to ensure you have correct settings. Good luck.
http://faria-instruments.com/site_manuals/IS0012u.pdf
I have to replace my gauages also, so wil monitor your success!!
