It's a "new to me" Honda BF8A
Have had the motor for about a month and have put many hours on it. A few at full throttle but mostly something a bit less and also have idled around for hours and hours. I pulled the carb shortly after I got it and inspected and cleaned but it was pretty clean to begin with. It ran fine when I got it but I wanted to get an idea if fuel had been sitting in there in its prior life.
Yesterday we took the boat for a longer cruise. The lake was flat calm so we were able to run at 5800 for quite a while.. probably 20 or 30 minutes. Ran GREAT. When I slowed down at the end when I got to about 1/2 throttle it started to stumble. When I dropped down further it died. Never got even near idle on the throttle. When I tried to restart, it took a full choke to start, but I had to keep the RPMs up near 3000 to keep it running, but I also noticed that the green 'oil pressure' light was NOT lit like it normally should be (and was on the entire trip down). We let it sit for a while as we were at the sandbar but when we went to leave (3+hrs later) it was the same thing. I checked the oil and it was well over the min 200ml mark but nowhere near the full mark. I was able to get it started and make the run back at over 4000 RPM without issue but when we slowed again it died. The oil light did not come back on at all.
Back at the camp, I checked the oil pressure switch. It is open at rest and closes once the engine is running. I thought the light might have burned out, but later that evening I was able to get the motor to start and run at everything but below around 2000 RPM.
I am going through the carb again and chasing all the low speed circuits. It is the same keihen carb that's used in the Tohatsu/Merc/Nissan except a bit larger and jetted larger. Looking over the ignition, it also mirrors the early Tohatsu that had a separate exciter, pulsar, CDI module and coil, except the function on the oil light is inverted. None of the documentation I've seen so for indicates that the low oil will interrupt the CDI like the Tohatsu ones do though, but I'm not 100% convinced about that yet.
Anybody with experience on these?
