not supposed to do that
- Joined
- Aug 14, 2013
- 2
hi i have a 90's ish honda motor (bf 9.9 longshaft) and it recently might of overheated and i flushed the coolant system with compressed air as well as low pressure water, then i removed the lower unit and found that the pump housing was partially deformed due to excessive heat...so i had to get a rebuild kit. Also i did remove the plate underneath the pump housing and removed the impeller chunks from there. once i re-assembled the motor it seemed to run perfectly fine but i noticed that while you run the motor the lower powerhead will squirt out water and possibly exaust as well and it fills up amazingly fast :facepalm: . could it just be a blown gasket....or should i get ready to spend some money?
