I just recently purchased a 14' mckee craft and wanted to power it with a 25-30HP motor. I have never owned a boat this size with an engine this powerful and had a few simple questions. One would be, which would be better to get in this small boat; 2stroke or 4stroke? Or is this just personal preference. Also, I put this in Honda section because at the moment, I am considering the Honda 25-30 because it has a 5year warranty. If any of you purchased new, did you get this warranty and is it worth it? (Honda seems to be a little more expensive) How does it compare to Evinrude, Merc, Yamaha etc..? Also, this boat is a '71 hull and while there are no serious signs of a bad transom, I am just nervous getting a permanent engine that drills through the transom. Would the people who install the engine be able to make sure its in tip top shape before this, or should I get a "portable" version with clamps? Last but not least is cable steering and ignition: I would like to have both pull start and electric start though I dont think Honda makes this. I am building a small side console, and apart from the engine, would like to know how much it would cost is all I wanted was the throttle, and steering cables to the console. Some tiller versions of Yamaha seem to be over $500 cheaper than the remote, and it seems to only costs ~$400 to convert, so that would save ~$100, just add some DIY work which I enjoy anyways.
ALL info, would be great. This is my first boat and I want to get a new engine so I can actually go out and enjoy myself for a long time. I just need help on the basics!!
Thanks.
Thanks.
