Honey, I split the boat!
v1_0
It's the same old story: noticed a couple of soft spots in the deck, drilled a few holes and found rot. Pulled the deck off, and noticed some discoloration on the stringers. Cut a bit off the top of those, and found mush in places that used to have wood.
Really, there's only three choices at that point: repair the stringers, replace the boat, or have a viking burial. Since I'm posting in the "Boat Restoration, Building, and Hull Repair" forum - and not in jail - it should be clear that I didn't go with the viking burial thing. Although at this point I'm thinking that it would have been more enjoyable and less costly (jail time and fines considered) than what I ended up choosing to do - and I haven't even completed all of the tear down yet.
My first step was to split the boat in half so that I could get at all of the bottom half/stringers - and do a full assessment of all of the rot to the stringer/support framework of the boat. I couldn't do this with the top on because the very front of the top shell has a fiberglass bottom that rests on the deck, as should be visible in these pictures.
The boat is a 1989 21' Galaxy Cuddy Cruiser, with a Mercruiser 4.3L Alpha.
Assessment involved removing the engine and outboard, getting rid of all the wet foam, then cutting the tops of the stringers in a 'V' (to preserve their height) and to take a good look at the wood (or lack thereof) in the stringer.
After the assessment, the plan is as follows:
(1) Remove any rotten/soft wood.
(2) Treat any remaining wood with CPES (Clear Penetrating Epoxy Sealer).
(3) Fill any voids with SeaCast.
(4) Patch any fiberglass that I had to cut.
At this point, I am about 170% through step 1 and about 90% done with it. Why 170%? Because, as the song goes "The stringers are connected to the - engine supports, the engine supports are connected to the - transom". Plus there are some other random wood pieces connected to the stringers at various places. Most of which had some level of rot to them.
In regards to the plan, CPES claims to be able to penetrate deep into good, soft, and even 'bad' wood with some sort of solvent 'carriers' and deposit epoxy into it making the wood virtually 'rot proof'.
SeaCast is a pourable transom/stringer (ie: wood) replacement that proports to be lighter and stronger than the wood it replaces. It is also 'rot proof'.
Based on the literature from both products, they should be compatible - CPES is formulated from wood (".. the resins are derived from wood pulp.."), and SeaCast seems to bond to wood. (They do warn that this will create a 'shear point' because of the strength variation between it and wood, so I'll need to make sure that I don't create a 'butt joint' and go for something much more angled).
Finally, I'll use regular (West) epoxy and fiberglass - both to repair the stringers up to their original fiberglass thickness, then to build them up a bit more to make sure.
More pictures / status to follow.
Bob_VT
Re: Honey, I split the boat!
Polyester resins, epoxies and fiberglass cloth are NOT good with CPES. During the time I have been here I have seen mention of CPES and not good results. It only penetrates 1 to 2 mm and all it does is encapsulate.
Seacast is good but costly.
Based on your boat.......a good plywood repair with regular resin will be fine. All of the "claims" of CPES have never surfaced here on iboats. It is their website that sells the stuff making the claims.
Consider this. You have a boat built in 1989 and it has lasted 23 years with regular fiberglass / poly resin...... how long are you intending to keep it?
I am just advising you are mixing too many products and spending allot of money. There are no shortcuts. You can not seal things with cpes and then think epoxy will adhere properly because it will not. The other caution I have seeen from the cpes is the bad chemicals and fumes which are poison.
You can do what you like but I am just trying to save you a few bucks with a still quality repair that will encompass the same amount of time. Poly resin and fiberglass is the fastest.
Have you priced seacast? Nidabond which is similar is cheaper. The best plan of attack is to read through what is being done and what has been accomplished.
pictures are not wrking for me. i like mushy as its easier to work with but theres no fixing mushy wood other than removing it. most mushy is on the bottom so that will be a neat trick to pour the sea cast under the good wood. other than the expense i can not see anything wrong with cutting the cap off the stringers and digging out all the wood then prep (sand accetone inside) and use sea-cast but that leads to some problems as the cross beams between the stringers are not all touching the hull so theres no pocket to pour the sea-cast into people have done it that way and have had good success. no one is going to cry if you have to leave 12"-16" off wood on the tip off the stringers if it means adding 100 hrs of work to get to that piece but no one is going to surgest a bad fix either....ive noticed in iboats that advice is payed for in pictures the more you post the more advice you get so open a online picture account and post the links (pictures are never to big or to many)
