Hooking up a tach
Snoopy-2
Replaced the tach which was not working and rehooked all wire correctly and it is still not receiving and pulse signal. The pulse wire is grey and I loose it in the harness trace. Some one told me that some times the wire goes into the shifter assembly before reaching the tach. I opened up shifter assembly and did not see any grey wire. (see attached photos) If I can not locate the wire in the harness what is my next choice of options. Can I run a new wire directly from the tach to (where ?). Also what is this white square 2 wired unit in the shifter assembly for?
Snoopy-2
Re: Hooking up a tach
added 2 more pics
its on a 1988 whaler with a 98 johnson 115
175se
that white square thing looks to be the warning horn . I would find the main harness (big black harness comes from motor) before ign. switch and look for grey wire your problem could be there. I believe it was boobie that gave a site for wiring diagrams for different boats in another post.
Snoopy-2
175se--Thanks found what I needed all OK now. Works fine. Thanks again.
Snoopy-2
Went back and double checked my wire hook and found out I had connected a ground wire to the pulse wire. I kick myself for not double checking- When I installed the new tach it was getting dark and I miss read the wire colors --that was all it was. Point to myself DOUBLE-CHECK every time. I could have done some thing worse. I forgot my number one quote-If you can't find the time to do it right the first time then where will you find the time to do it over?
