Slick Rick
- Joined
- Jul 26, 2011
- 33
Hey guys... Hooking up the power for the new outboard. The old motor looked nothing like this one so I was to make sure I hook up to the right spots.
I believe the power should connect to the right side of the solenoid (lower center of pic where nut is removed) and the (-) should connect to the upper right bole mounting the starter.
If that configuration is correct, I have verified the following
Power at Solenoid
Continuity between both large solenoid lugs
Continuity between switch terminal on side of solenoid
Continuity through neutral switch circuit
When I turn the key I get nothing. No click, clank, or other. The ignition system (boat side) worked with the motor I took off a few months ago, so I'm leaning more towards the new motor I'm putting on. I only see 1 fuse (20amp) on the motor. Are there any others I should be looking for? Breakers?
2000 40hp ELPTO 2cyl.
Thanks,
Rick
Power at Solenoid
Thanks,
Rick
