Re: Hooking up water with the outdrive off
from experience, you need to start the engine before turning on the water. and shut the water off before turning your engine off. if you turn the water on and then start your engine you are in high risk of hydro locking your engine. then you have to pull the plugs and flush the cylinders of water and also change the oil and hope you get all the water out with one oil change! the impeller in the outdrive stops water from entering your system when it is not running. just speaking from experience. my experience was on an 88 omc cobra 305. good luck
