Re: Horrible Fuel Economy-Causes?
the test is top secrect.
cant tell ya without national security and Homland getting involved.
oh well they can just arrest me.
a quick simple test?
hold your fuel primer bulb with the arrow straight up. engine off.
pump the bulb till its nice and firm.
then keep pressure on it,
if it goes soft in your hand either your check valves in the primer bulb failed OR fuel is leaking past a diaphram or a carb needle.
if the bulb stays firm without exceptional pressure by hand then odds are high the diaprams are not leaking and the carb needles are sealing.
like I say this stuff aint rocket science, if I can do it most resus monkeys can.
let the engine idle for about 10 min, hold your hand on both heads, if the stbd head stays cold you may be fighting something as simple as a bad Tstat.
if the stbd head,for any reason, goes below 113*F on that motor it opens the enrichment valves cause it thinks its cold.
more fuel, more slick easy to find and the thermosensor cn be tested with a standard ohm meter and some knowledge.
ya gotta remember, totally rebuilt can mean anything from it was repainted to it was actually reconditioned.
if I did not rebuild it ,or a few select techs I know, I have to assume it was patched up and sent out.
trust me its the way it usually works.
so far you really havent given us any data to work with.
without it we cant help.
what I can tell you is if you do a link and sync exactly like the manual says and it idles at anyting other than spec, it freaking broke.
on this ttype engine,just like ALL ECU controled motors and ALL EFI motors there is NO idle speed screw.
it either works as designed or its misajusted or broke.
my time is billed at 85 an hour. I wont rebuild a low pressure pump cause the parts are about 25 dollars and when the time is tossed in you just got a rebuilt pump for about 10 bucks over the cost of a new one.
however its very simple and easy to do.
I actually dont make a nickle off of parts sold and I do try to save my customers cash.
and like I told you, above about 4200 RPM 20+ GPH is rather normal for that engine.
