Horsepower Question
whartonlax24
I just bought a 1956 Evinrude Fastwin and dont know how much horse power it has because the previous owner was cluless and didnt know. How do you tell how much it has?
Bob547
Re: Horsepower Question
Hello, My friend has a 1956 Evinrude, its 7.5 hp. Post a pic of the engine, im sure someone here knows what it is....Bob
F_R
Lightwin = 3hp
Fisherman = 5.5hp
Fleetwin = 7.5hp
Fastwin = 15hp
Big Twin = 30hp
Above are all 1956 ratings.
jay_merrill
What FR said. If you want to be sure that it is really a fastwin, post the model number too.
jbjennings
Does it look like this? ('56 15hp fastwin)
I love mine....Bet you will like your's, too.:)
JBJ
whartonlax24
yeah i know, one of the origional owners wrote 1956 on the inside so i guess thats where he got it from. Heres the model no: 15024 - 05796
whartonlax24
The motor also came withe the origional tamk and i was wondering what the clear plastic peice is right in the begining of the fuel line is because it leaks when i prime it.
tashasdaddy
1958 15 hp, super great little motor. mine did not have a clear piece in fuel line. picture would help.
edit, me bad, typo it is 18hp
Vic.S
The list i looked at says 1958 but 18 hp
wbeaton
Yes, its an 18 hp not a 15 hp. Nice mtor.
whartonlax24
dytdc.jpg Herest the pic of the broken part on the fuel line. And i got the motor, gas tank, 14 foot fiberglass boat and trailer for $400
jbjennings
It looks like a cheapo fuel filter or water separator. If you have the glass filter bowl under the cowl,then I'd just take the filter out of the hose and problem solved. If it's leaking on the side of the filter without the hose clamp, then a hose clamp would cure the problem. I'd take it out though, it looks easy to break.
JBJ
tashasdaddy
do away with the filter, my bad typo it is an 18.
whartonlax24
thanks, i took it off and it dosnt look like it dose anything besides "waste" gas
Vic.S
Yes that looks like a filter. If you need it why not fit it under the cowl where it will be protected.
I dont like worm drive clips on small diameter hoses. Any joints that will be permanent should have double ear O clips crimped on and any that need to be undone would be better with nut and bolt type clips. IMHO
whartonlax24
Yeah we are putting new fittings on most of the hoses today, but most of them look fine because the motor is in excellent condition
whartonlax24
also, on the inside of th engine housing it says that 6 gallons of gas should be mixed with 2 pints of oil is this true because it seems excessive?
tashasdaddy
mix is 24 - 1 gas to tc-w3 outboard motor oil. they were originally run of 30 wt motor oil prior to outboard oil.
