I bought a 1987 150 XR2 last October. Have ran it on several occasions. From the time I bought it, it always ran great. Trouble is, if I keep it at or below 4000 rpm's everything is fine. Over 4000 rpm's and the HOT alarm will sound. I had installed a new water pump after the very first time the alarm went off. The water pump housing looked great. I installed a temp gauge last weekend and the temp reading is around 215 at 4000. Anything above will peg the gauge and the alarm will sound. To start with the trouble shooting, I checked the poppet. Seems to be working okay. Next I ran a compression check. The top and second cylinder on the starboard side reads 112 and all the other cylinders read 115. Think the top end is okay. I then dropped the lower unit, and this is where I have a question concerning the plastic connector that connects the waterpump to the pickup tube. The plastic connector sits down in the waterpump housing fine, but where the plastic connector fits over the pickup tube, its loose as a goose, sloppy, floppy!! Should there be a grommet or seal that would seal the plastic connector to the pickup tube? I can't imagine how the pump could pressurize the motor with this kind of fit.<br />Any help would be appreciated.<br /><br />Thanks...Southern Catfisher
