1989 Mercruiser 3.0L
After charging my starting battery, I tried to crank the engine and it starts the first time. I then shut it down and try to restart and the starter slows down dramatically and fails to crank the engine. The + and - wires to the battery, to the starter and main ground, are extremely hot. I tried an additional battery that is known to be good and the same thing happens.
It sounds like a short somewhere causing the heat to build in the wires so my first step is to clean and/or replace the terminals. What else do I need to check?
