Re: hot evinrude 110
On crossflow V4s like yours the telltale water comes from the cooling circuit near the beginning and will never get warm - it hasn't traveled through the motor yet.
I would do what gejandsons did and remove the thermostat end of the cooling hoses. Start the motor and see if you're getting flow that far. If the water gets through everything and makes it to the heads, then the motor should be cooling to that point. A LOT of water should come out the hoses, not a dribble and no steam.
A lesson I learned on my 90hp was to make sure the tiny passage in the top of the waterpump housing, between the cup and housing where the large o-ring sits sandwiched between them, is free of sealant. I was a little overzealous with the sealant on mine and it would lose prime at anything above idle speeds. Mine would pump at idle and stay warm, not hot. I would get the boat moving and shortly after I brought it on step it would start to overheat. Drove me nuts before we figured it out...
- Scott
