HOT HORN
djzyla1980
Ok... since she's running right(as far as I know) and I want to take her to the lake today thought I would question the hot horn.... so I grounded her out and nothing.... no light horn nothing. Where do I start in the control box or on the engine??
Silvertip
Re: HOT HORN
Did you have the key in the RUN position? Did you disconnect the tan wire and ground the wire from the sensor or the end of the wire going to the horn? If you grounded the sensor wire, nothing would happen.
OBJ
Re: HOT HORN
Dave....did you try grounding from each head? Each head has it's own temp sensor. If nothing from each sensor, split the control box and remove the alarm horn. Put the contacts of the horn across a battery and see it works. Most likely the horn is dead or a poor contact to the horn.
djzyla1980
Re: HOT HORN
Haven't checked ground in control unit yet.... Will do that tomorrow...<br />Yes I grounded it to the head... I'm thinking dead horn on this one
OBJ
Re: HOT HORN
Dave....don't overlook the ground inside the control box as BassCat suggested.
Dhadley
Re: HOT HORN
1970 115's didnt have a horn. They had a light.
Basscat 1
Re: HOT HORN
Yea, thats right they had the push button control.
<br />I always thought those were neat.
djzyla1980
Re: HOT HORN
Do you want it basscat.... cause it's causing me alot of pain..... and time... I'll throw the motor in for free also...lol One day....one day it will be right...<br /><br />Back on topic Since it's a light... can you replace bulbs or try to find the whole thingy (light cover and all) or am I outta luck on this one?
alden135
Re: HOT HORN
I replaced my crusty old light with a generic one from the auto parts store. My light was dash mounted so I just bought a push in lamp holder. I think it was 2 bucks.
OBJ
Re: HOT HORN
Good ol' Mr D.....keeping us straight again.... :)
