Hot Horn
da83moon
Guys went out to the water and ran my rebuilt engine. Worked great, however I had a problem with hot horn. I realize its got a job to do and all, however on mine as soon as I started it it went off and stayed on. Well after a 5-6 minutes it stopeed. MY engine wasn't hot to touch and actually felt very cold. Then it happened. Smoke started to come out of control box and I was like oh crapt. I unhooked the battery and then proceeded to take the box apart on the water. Well the hot horn was so hot it burnt a place in the leather glove I was wearing like a brand. It shorted out the fuseable link in the engine harness. I'm thinking it shorted out, do you all think the same?
Also having trouble with idle. I know this is popular and just need to know if I have more than one adjustment for idle besides the idling screw itself? It will do great when I set it on the water and then all of a sudden dtarts sputtering and dies. I know taht the jets are fixed, however is there any kind of muxture screws on the carbs that are adjustable to obtain good idle?
Ening 1979 55 HP Evin.
wilde1j
Re: Hot Horn
You need to take the carbs apart, soak in cleaning solvent, make sure all ports are clear and blow dry with air, then re-assemble.
da83moon
Re: Hot Horn
Okay got the hot horn replaced and works fine.
However I took everything back apart and re cleaned it and I'm still having the same troubles. I did do the rebuild kit initially and this engine still is not idling right. Sicne the jets are fixed waht adjustments do I have and any more reccomendations are very much needed. I know there are air jets, ut can you adjust theses
