Hot Merc 5.0L TKS ?
Bayl305
Hi all.
Engine, 220hp, serial ; 0W312399,2400 with bravo2 , put deep down in a Bayliner 305 Ciera
Im concerned my enginge`s running to high above normal temperatur.
Gauge readings on Starboard enginge : 175 F
Port Engine : 180 F
I didnt changed the gauges yet for checking the readings.
What is normal temp actually? We use the boat in salt water but always flush after every trip.
I know for shure that the thermostates are original and opens at 160 F , Ive checked them both..
The temp slighty raises at 4000 rpm on bth gauges but with no more than 5 F
So any reason to be concerned?
Thanks in advance
180shabah
Re: Hot Merc 5.0L TKS ?
Given the "accuracy" of those gauges - sounds good to me.
How long since your last water pump service?
Do you have an IR thermometer?
Bayl305
Hi
I changed the impellers in the raw water pump last month but never had service on water pump mounted in front of the engine..
Nope no IR therm but guess i should get one
Thanks for answering me guys, i feel more relaxed reg temp now :)
Bayl305
Bought IR therm and readings on the hottest spot on the side of manifolds shows ; 167 F (75 C) on all 4 sides, so i guess its time to relax
Thnks Guys ;)
