hot rod sound
Red9654
is it the cam shaft on a hot rod that gives it that rough idle sound?
JB
Re: hot rod sound
Yup.
LippCJ7
Re: hot rod sound
yes it is, a big cam can give a motor that lope that just sounds bad a**, but keep in mind that there are other ways to make a motor sound bad as well
Blower Surge
Blower Surge- Drag boat - YouTube
but a cam is pretty awesome!!
Good to see you posting again JB Welcome Home, we missed you!
rbh
Re: hot rod sound
And usually the exhaust system is a whole lot easier flowing.
MH Hawker
Re: hot rod sound
Its a combination of things mentioned the cam and exhaust is what most hear. Aint nothing like the bound of a big block with 11: 1 pistons and a mid range degree cam and headers.
WIMUSKY
Re: hot rod sound
Except you wont be running that 11.1 on pump gas..... Unless you're running aluminum heads......
avenger79
Re: hot rod sound
a cam with no other changes will give you a sound that for the most part only the guy who put it in can hear. the "hot rod" sound is gotten through a combination of many things incuding, more air in, more air out, more fuel, different timing, etc. it can be done in "baby steps" and you will notice the sound getting more aggresive at each level.
And to reiterate the above statement -------blower whine----- yeah baby!!!!
Bigprairie1
Re: hot rod sound
The lumpy idle sound typical to most high performance engines comes from having a camshaft with a long duration wherein the timing events of the intake (valve) and the exhaust (valve) have a fair amount of overlap.
That means that the intake valve is opening and 'overlapping' during the exhaust stroke where the exhaust valve is also open, etc.
The reason for this is as the engine speeds up to high rpm the overlap is required to produce an efficient (thus powerful) result by having the events work in good unison for both filling and evacuating the cylinder....but only really at high speed (ie: above 5000 rpm generally)
The downside is that at low rpm you have very little engine vacuum for things like power brakes and you are more likely to suffer from plug fowling, etc.
The other downside is that low speed performance and particularly torque suffer greatly with a very long duration camshaft which is a disaster in a heavier vehicle like a truck, etc or anything over 2 tons.:eek:
The camshaft is one of the most mis-understood and, more importantly, most incorrectly spec'd parts that people choose and put into their engines with the results often being very disappointing for most of their driving needs.
Always talk to the tech people at the camshaft manufacturer (Comp Cams, Lunatti, Crane, etc) to discuss what would work well with your application.
My two bits.
BP:)
jkust
Re: hot rod sound
I love that V8 sound. Only time my 4.3 sounds good is when I am summarizing it with the muffs in the driveway.
