Heating trouble with my 96 Evinrude 112spl. After several minutes of operation, the HOT light comes on, pee-line is super hot and I need to shut it down. From what I understand the pump and impeller are less than 1 year old and are very beefy for this model engine. Also there is water dumping from the slots in the lower unit above the prop (See picture), which I believe is a symptom of the Thermostats being stuck / not functioning properly.
Next question is...can the thermostats be accessed / replaced without removing the lower engine cover. That looks rather difficult to remove. I can get at the 3 bolts holding the Tstat cover, but not sure what I will find inside the housing and whether I can get my fingers in there to do whats needed. Are there any special tools I'll need for this replacement. any other words of wisdom.
Thanks
dean
Thanks
dean
