Re: hot water
I have an 85HP Force O/B & added the "Tell-Tail" to it. The first time I had it out the "tell-tail" worked fine, but not the powerful stream of water I was expecting & it was Very hot. The first thing I thought was the impeller was warn out. I was afraid of frying the motor so I had a new one put in for $60. The mech. that did it said that it was working, but needed to be changed. I now at least have piece of mind & don't need to worry about that for awhile. The water that comes out of the tell-tail with the new impeller is still warm, but not hot. I'm not sure what temp. it should be, but I don't think Hot is good. For the $$$ why not have the impeller changed like I did. If you do it yourself the part is only around $20 & there is a "sticky" thread in the beginning of this section on how to do it yourself. Hope this helped.
