Hot wiring a 1986 35hp force
mikmic2
Hello,<br /> I was just curious as how would one hotwire a 1986 35 hp Force. I have omc ignition that was being used for a 1985 force. So I was thinking I could use it for my 35hp force. <br /><br />I can ohm out the switch and figure out the contacts, but I need to know what wires should be connected in the on position, and the off position. I can figure out the Start and choke part of it. <br /><br />I looked in my Clymer Manual and it just shows where the wires go on the switch and not which ones are connected when.<br /><br />I have a blue magneto wire.<br />A white magneto wire.<br />These two wires would go the the two M's if I was using a normal switch. I don't have another switch to compare it to. <br /><br /> <br />A hot wire of course. <br />Green for choke. <br />Yellow for start.<br />And the purple I am not using as I do not have a tach.<br /><br />So what should the magneto wires be connected to when it is running? When it is off?<br /><br />Any help would be appreciated for knowing what wires should be making contact in the off and on positions. <br /><br />I already know that when I turn it to start the Power and yellow should contact. I know that when I push the key in the Power and Green wire should contact, for the Choke. But about those magneto wires?? <br /><br />Anybody????
roscoe
Re: Hot wiring a 1986 35hp force
The two magneto wires will connect to each other when the key is off. <br /><br />Look on page 582 of the Clymer manual.<br /><br />When the key is off, the wires are connected, and the ignition is grounded out, no spark, so the engine stops.<br /><br />So with the key off , battery disconnected, check for continuity. The only 2 that have continuity should be your "m" terminals.
mikmic2
Thanks a bunch Roscoe. I think You've probably answered just about every Force question I've had, and I appreciate it.
roscoe
Not many come here to the Force forum to offer any help, and I have no life, so I do it. :)
mikmic2
All is well with my ignition. <br /><br />However, as usual, I have another problem that I posted as well. :-( LOL
