Re: house lighting dimmer switch question..
You're not using 100 watts (the dimmer doesn't waste 50w, or it would get blazing hot), but you're not using 50 watts either. <br />That is to say, if you run a 100w lightbulb with 50w of power, it'll be dimmer than a 50w bulb running at full power. Not much dimmer, but definitely dimmer.
<br /><br />The cooler (and redder) a light bulb's filiment is running, the less efficient at producing light vs heat it is. Like those damn 60w candalabra bulbs that get hot enough to give you 3rd degree burns but don't provide much light.<br />The opposite would be halogen lights, which burn their filiments much hotter than a regular bulb. Which is why they're more efficient/brighter for a given wattage. <br /><br />Arn't you glad you asked??
<br /><br />(You ever notice the 25w, 40w and 60w candalabra bulbs make all about the same light? Or is it just me?)
