Re: Houston Area - Winterizing?
I am a new boat owner and just got a 93 Regal Valanti 176 SE. The boat will be stored in a shed with cover on 3 sides but no front door. I also have a boat cover that will be on it. It has the 4.3 Mercruiser in it. Is winterizing a must in this part of Texas?
We dont get freezing temps for longer than a few hours at worst and they only happen about 2 or 3 times a year.
Ayuh,.... Welcome Aboard,.... It only takes
Once,...
I don't care if ya do any of the maintenance that should be done at winterization,...
But,......
The One(1) thing, ya Gotta do, is
Drain the water system,...
Yer motor should have a block drain on each side, just above the oil pan rail, 'bout mid-way the length,...
Just above those 2 drains is another drain for each of the exhaust manifolds,...
Take a nail/ screw/ piece of stout wire, 'n Poke those holes to knock the crud outa the way, so All the water comes out,...
At the front of the motor, pull the Big hose off the circulatin' water pump, it hides a quart or so,...
If ya got P/S,..??... the Cooler is in the in-comin' water line, 'bout under the portside motor mount,...
Pull Either of the Big hoses off it,...
Get yerself a "Hose pick" to help pull the hoses off,....
