Bigprairie1
- Joined
- Jun 13, 2007
- 2,568
Ok, after many, many faithful seasons my 20+ year old force (1990/90hp/3 cylinder) may have pooped it's pants.
I was about 100' from the dock, throttled it back and noticed the motor running rough and poor...but still running. After another 15' it stalled out...then restarted and limped back home. I pulled the plugs today and did a compression test and it reads as follows: Top cylinder: 115 psi, centre cylinder 65-70psi and the bottom cylinder 120 psi.
So.....did I break a ring?...or..two rings or a reed valve or????
I intend on pulling the head off and taking a look in there and will post pictures...but any feedback, advice or history that you may have fellow IBoaters with this predicament and how to fix it would be greatly appreciated.
Now...on the upside, I bought another complete 1991 Force 90hp several years ago which has been gathering dust in the basement. It has 140+psi compression all cylinders but I need to install the flywheel on it and the leg to get it 'back on the water'.
All input is most welcome.
Thanks guys!!
BP
Thanks guys!!
BP
