So today I was running my motor four miles from the docks when it died. A very mechanical sound from the motor was heard. Needless to say after cooling down I returned limping to the docks. I came home and took the powerhead and exhaust gasket off to see this: <br />
<br />I then looked at the oil pump lines and they were dry. The top piston is scored to hell. The second is a little better, and the bottom is worn but not dead. How bad does it look? What are my options? Can I still run the motor and what will be different now that the pistons and walls are scored so badly? I think I was negligent with the oil pump and failed to bleed the oil out from my last mechanical incursion into the motor. How bad is it doc?
