superbenk
- Joined
- Oct 27, 2008
- 2,033
I have a new prop on order but it won't be here until next week. I'm wondering if the following prop looks too beat up to use for the weekend in all of your opinions?
The prop is only a week old but I picked up a rock loading the boat on the trailer at the end of vacation
You can see there are some chips out of a couple of the blades and they've all been scraped up. Nothing appears bent that I've noticed.
I also have the original 3-blade prop that I was replacing with the 4-blade. The 3-blade got chewed up early in the same week. Both strikes were due to low lake levels (expensive week):
Again, none of the blades are bent as far as I can tell, but there's clearly a chip out of the blade. The 3-blade spun the hub, but I can use the hub from the 4-blade in it if necessary (both are Mercury props so the Flo-Torq hub should be interchangeable).
