Re: How can I increase HP on a 72 Evinrude 25HP?
Iron Ranger,<br /> One thing to keep in mind - pretty much all of the advice here is stuff that will basically make sure your motor is putting out its rated 25hp. If your 30+ year old motor is like most I've seen, they're a bit on the tired side, the throttle linkage has some slop, the rings have some carbon in the grooves, the crankcase seals are less than perfect, etc. That said, all the work you do will, when you're done, give you a 25hp motor. A fairly high-strung one at that. As good as the 25s were, they made their 25 horses from the time-tested 22-cubic inch block. Getting 25hp from the block required a lot of tinkering on the part of the OMC engineers. Getting MORE than 25hp isn't terribly realistic on anything other than a stick-tower, 16:21 gears and a 115 lb. hydroplane (as run in 25SS class APBA racing in the early 1970s). <br /> Follow the good advice to prop the motor to your boats load at 5500 revs, do a good de-carboning and make sure your motor is putting out it's rated power....<br />- Scott
