How can I slow my boat down
chaspee
I have a 21 foot Privateer with a 150 Evinrude<br />The large engine is great for everything but crabbing I need to go really slow and dont want to tow a bucket I would like to change props so I can idle at higherRPMs and the boat move slower<br />and maybe not load up so fast Thanks
12Footer
Re: How can I slow my boat down
You could re-prop it, but you would run the risk of over-reving it at WOT. Have you ruled-out a trolling motor? That's whats river-rato down here with out bass and flats rigs (install the best tm we can afford). It gives you the added benifit of high manueverability while not hindering your other performance in any way.<br />You could also install a "prop-gaurd", and it may cut down your idle speed enough.
D
DJ
Guest
Caspee,<br /><br />The easiest way is to install a trolling plate.<br /><br />Look here for one: www.cabellas.com
22WRF
Trolling plate also available thru Pro Bass Shops
chaspee
Does a trolling plate have much affect on handling
