How can I strengthen my bench seat?
jtrom
I have made a 3/4" plywood bench seat that mounts across the curved floor of my 15 ft. aluminum boat. It sags badly when I sit on it. How can I increase it's strength and rigidity without making a bracket, ect. that touches the floor?...I was thinking attaching a piece of foam underneath and then adding 2 layers of fiberglass cloth/resin......could it work?
paultjohnson
Re: How can I strengthen my bench seat?
Ummmm Are ya sure its the seat that is weak? How much does the Captn' weigh ??? JUST KIDDN'!!! ;) A piece of aluminum or steel angle or channel underneath might give it what ya need. A pic of your set up would help with our creative imaginations.
jtrom
A piece if angle would be the easy way out, and I am trying to keep it open underneath to be able to slide fishing poles, a paddle, ect. underneath the seat....
paultjohnson
Wow, real pretty wood work ! I think a piece of angle iron or whatever from side to side would work just fine. Nothing to the floor. Some iron channel with a 3/4 in channel on for and aft edge maybe? do you plan on putting a cushion or something over it also ? Love the boat ! Plz post pics when completed !
paultjohnson
Another light bulb just went off. Frame the current seat with 2x2s or 1x3s or whatever ya want, Then put a hinged lid on it. You would gain rigidity AND a nifty little storage area.
jtrom
I like the angle iron idea, thanks! Thanks for the compliment...here is a pic with the epoxy on it.
Woodonglass
I think if you just use 2 pieces of plywood for cleats, 2 1/2" wide glued and screwed to the undersided of the plank you would get what you are looking for.
64osby
My old boat had a center support of 3/4' Ply.
robert graham
My 2nd on this!....It'll stiffen up that seat just like you want it!;)
Cadwelder
Well you mentioned glassing, so take a 2" carboard shipping tube and split in half, glass the two halves underneath the seat and she'll be strong as an ox. Just a layer of mat and some type of heavy cloth just over the tubes... (1708 scraps, 1700, 12 ounce cloth, etc..)
CW
jigngrub
A 1 1/2" bench is what you need, either 2 pieces of 3/4 ply laminated together of a 2x whatever.
