Re: How can I test a starter?
DONT USE AUTOZONE!!!!
Their tests are a joke, not a funny one eather.
The best way is to have it tested at a starter/alt. shop.
If you really want to test it at home,
find a block of soft wood, hook up NEG to starter case, then POS to lug.
Have a friend hook up the other end to a good batt, then while holding the starter firmly shove the block of wood into the gear, (it will be ok).
If the starter stops or slows down then its no good, if it keeps constant and starts burning the wood its good.
Ther is no way to check one properly without a load on it.
This was taught to me by an old guy at the local reapair shop.
Hes been doing it that way for more years than i have been alive.
