How can I test my fuel Pump?
Hukeedo
Having trouble still and suspect fuel pump. Is there a way to test it? I'd like to try and test it before i tear into it (fuel pump)and have to spend money replacing or rebuilding. The motor is a 1972 Mercury 500 thunderbolt 50 Hp. It's dying when I put it in gear and really hard to start unless I keep squeezing the heck out of the primer bulb.
Thanks for your reply's.
sschefer
Re: How can I test my fuel Pump?
Two things can cause that. A bad check valve in the fuel pump or a bad squeeze bulb. The fuel pump is usually cheaper to rebuild than a new bulb.
The fuel pump test will take just as long to perform as a rebuild. Just rebuild it. I can do a merc/mariner in about 20 minutes including check valves. It will take you about 30 if you read all the instructions in the manual first.
Laddies
Banned
Before doing anything richen the idle screws 1/4 to 1/2 turn
Hukeedo
Thanks for the info and suggestions, i will try to richen the mixture and then rebuild the fuel pump. Going to order the kit tonight. Thanks again.
