How can you find what model/year with no I D plate?
badford
Long before I got this 60 HP Johnson, the swivel bracket that has the I D plate had been welded on. Whoever did it, had to remove the plate to do the welding. Guess he didn't know how to put it back on. Reguardless, its gone & I need some parts. Actually, I already ordered some. I thought it was a 1985 because that's the first year the 60 HP came with the VRO? I matched some of the P/Ns on the engine to 85, but now I need the plastic gears in the remote control & those #s don't match. The parts guy at the shop needs a model # & said to look under the carborator. I didn't ask if it's a plate I'm looking for or stamps in the block. But I see nothing. I did find "18LJ 2" stamped in the top of the block above the water passage cover. Means nothing to me. Someone know of an easier way to find this info other than writing down a bunch of P/Ns & seeing what they're used on most?
OBJ
Re: How can you find what model/year with no I D plate?
Usually there is a large welch plug on the block about the size of a quarter. The model and serial number is stamped on there also. The plug is silver in color.
badford
Thanks OBJ, but you'll have to excuse me, I'm from a different part of the country. Just what might a "welch plug" be? Whereabouts would it be on the block, top? Starboard? Port? Please don't tell me the bottom.
deerhound
For whats it's worth on my Evinrude 40hp the plug is on top of engine starboard side. JBD
OBJ
Another term is "core plug". Usually on top of the engine for larger engines like JBD's.
F_R
Welsh/Core/freeze plug. A flat metal circular disc. Actually it was convex before installation, but flattening it out when installing tightened it into the hole and made it more or less flat. It may only have the serial number on it. Some have both model and serial. Generally unpainted because they were numbered after the painting process.
