Re: How did I lose 10 MPH?
Speed trap got you and took your 10 mph.
<br /><br />Don't be embarrassed to tell us you have a Force motor.
<br />Be proud of it, it still runs don't it?
<br /><br />I would say you are running weak on one cylinder.<br />So check the compression ( gauges are $29 at Sears or NAPA) , and the spark, and for gas to each cylinder. I bet you will find either no spark or low compression on one cylinder. <br /><br />What do the sparkplugs look like? Do they all look the same?<br />What year is this motor?<br />How high are the rpm going?<br />How is the holeshot?<br /><br />Could be just a head gasket or a bad coil, or it could be a lot worse.<br /><br />Let us know what the compression readings are.
