Good morning gentleman and ladies.
So to make a long story, even longer :joyous:
I have a Ford 351W and was having problems turning the crankshaft, so I ended up taking off the heads to see if there was an obstruction, or damaged head. The Engine had been sitting for a while, so I figured it wouldnt be a bad thing to change the gaskets anyway.
So I went off and ordered the gasket kit for the engine, and figured I should order a oil filter, so I took it off. and found a shot glass amount of water in the filter.
I havent pulled the drain plug off the engine yet, thats the plan for tonight, because it wasnt till this morning that the whole thing clicked in my head that the block might be cracked.
So I figured I would write up this post before heading into work, and maybe someone who is smarter then me can give me some idea's
- Right now, I have the engine block sitting on a frame designed to test fire on the floor of my Garage, made with 2x6's
access to the oil plug is a PITA right now. but I will figure something out.
- since pressure testing my block is not possible right now, you know with everything removed. what is the best way to check for leaks?
I read a post someplace that recommended putting acetone/paint thinner/either? and filling all the levels up so that if there is a crack, its going to seep out since its 4 times thinner then water.
I have included a link to my gallery of photo's I was making this weekend.
Basically, I am asking for help on how to figure out if I have a cracked block or not.
http://plus.google.com/u/0/photos/113265924173107068758/albums/5884982139440571745
