How Do I Determine What Size Trailer Jack to Install
Dick Sorensen
Replacing the trailer jack on a Shorelander dual axle that holds my 205 Rinker Cuddy. I am installing a 7000 lb. coupler. I cannot read any of the manufacturers data on the jack. I know I'm not lifting the entire weight of the boat....but how do you determine what size the replacement should be?
iop
Re: How Do I Determine What Size Trailer Jack to Install
If your trailer is set up right... anything 1000 lbs or up will suffice.
superbenk
Wow, 7000# coupler for a 20' cuddy is certainly more than sufficient! Tongue weight should be ~10% of the boat weight or so. I'd guess your boat is 3500# roughly, so you're looking to support ~350# (assuming proper setup). Giving a hefty margin of error & 1000# jack should be plenty in my opinion.
I'm making educated rough guesses on all these weights, so use my advice at your own risk.
Dick Sorensen
Thanks....I'll stop searching for a 7000# jack....was having a heck'va time finding much over 1500#! Thanks again.
Wingedwheel
just be sure not to get a cheapy. Mine is the right load rating, but it flexes and if I'm not carful it could fall. I should have spent the extra $20. Now I'm gonna have to spend what I paid originally plus that before someone gets hurt.
