Re: How do I determine what year my motor is?
That's a 1940 3hp outboard. Parts can be a little tough to come by for it, but many are available. The nice thing is that, if the motor turns over, has compression, and has spark, it will likely run for you. Very simple outboard. <br /><br />Try turning the flywheel by hand. If it turns smoothly, then pull it with the rope. You should be able to feel the compression. If it's there, then remove the sparkplugs, insert them again in the plug boots, and lay the metal body of the plugs on the cylinders. Turn the engine over again with the rope. You should see sparks on both plugs.<br /><br />If you do, and the plugs look OK and not all gunked up, put 'em back in. It's better to replace them with new ones, but I don't have the plug spec for that outboard right here.<br /><br />Next, inspect the fuel tank. If it's empty and clean, add a little fuel/oil mix (16:1 to start with), open the fuel petcock and see if it'll fire for you. Be sure to do this test with the outboard in a water barrel, with water up over the lower gearbox unit.<br /><br />It's often surprising with these old outboards. I've started a couple of Eltos of this vintage in less than 15 minutes from finding them.<br /><br />If it won't start, then you can begin running down the problems and trying to find the parts.<br /><br />Check aomci.org. They're the antique outboard club, and have many resources for these fun old motors.
