Re: how do i find the joe reeves method of timing
Reelsport,<br />Do a search in this forum for "Test Tank/Ignition Testing". The post was on Sept. 10 2003.<br /><br />I believe there may be an issue with this method if your motor has the Quickstart facility which alters the timing depending on time after starting & engine temperature. You can disable the temperature sensor by shorting the temperature sensor wire to ground.
