How do I fix a pull tube
Plainsman
Wasn't sure where to post this.
Anyone know how to patch a inner tube at the seam? I have a tube for my boat to pull people, but have a leak. Tried a patch kit a no luck.
TIA,
Eric
MTboatguy
If it is on the seam, you are going to have a very difficult time patching it, we have never been successful trying to patch seam leaks on our farm trucks.
Gyrene
You can try the goop in a can...
Remember old bike tire repair kits? A cardboard can with a metal top that had lots of holes punched in it? Well, that top was like a rasp - you need that to grind down the seam, then liberal application of glue on tube and patch - and patch MUST have rounded edges.
usually it involves buying an new tube
Tim Frank
Call the manufacturer and ask their CS folks.
Depending on the speeds that you use for towing, it may not be a good idea in any event, if safety is a concern for you.
I was on one that blew at ~ 50 MPH on a corner and I do not recommend the experience. :)
greenbush future
And your middle name isn't "Skip" either right? At 50 mph, that had to be breath taking...literally.
Tim Frank
This was in the days before the new breed of purpose-built "Cadillac" towables. It was a standard 10.00 X 20 truck tube.
Attaching the rope was an trial and error process; there was always chafing and wear caused to the tube.
Some days you are the windshield, that day I was the bug.
Limited-Time
Back when "tubing" involves a length of rope and real truck inner-tube. Just remember to point the valve stem down!!!!!
Bob_VT
Hey Eric have you brought it to a pool supply company. They might have some insight
