When putting my 25hp merc in my truck recently, I put the prop end into the truck first with the head on the garage floor so the engine was inclined at a 45 degree angle, head side down. After taking it out of the truck later and getting it back upright, I noticed there was an inch or so of water in the transparent fuel filter bowl which I had not noticed before. I assume it ran out of the carb float bowl and into the filter bowl when I had the motor upside down. So now I'm worried there may be more water inside the carb float bowl.<br /><br />Turning an engine upside down is a hard way to get water out of a float bowl so my question is, how do I get at the carb float bowl to drain it? It looks like there is a lot of stuff to remove.
