how do i get this off my toon?
Clutzmi
how do i get this off im in the middle of cleaning the toons with jjv's best and it does an amazing job but it didnt even touch this handprint can i use something like steelwool or scotch bright pad on it? i dont want to damage the toon itself.
Todd4
Re: how do i get this off my toon?
Are your toons painted white (or epoxy coated)? The pic makes them look so. (The handprint looks like its painted also, instead of grease.) If not, and you use Scotchtbright, the aluminum may look 'buffed' differently than the rest of the toon. People have had good luck with Magic Erasers.
Todd
BobGinCO
Wait a minute! That's a genuine Alumindian Metroglyph! Don't remove it, preserve it! Contact your local historical society! It looks like the Alumindian tribe has migrated into your area, and they're marking their territory!
Clutzmi
not painted or cooated i will give the magic eraser a shot
muskiemike12
How did that print get on your tube to begin with?
robert graham
Spray it with carb cleaner and wipe it off with a rag. If you use any abrasive pads(like Scotchbrite), where you clean it will look "shiny" and stand out from the rest of the toon....I have an unpainted aluminum canoe and have tried all kinds of stuff to clean it.
lncoop
Way to go Bob. Now the AMPC will see this and cite him for attempting to deface a marianthropological "treasure". Some times I wonder where your head is.:rolleyes:
BobGinCO
Just think of what he'll be able to sell the boat for!
Museum piece for sure!
5150abf
As Robert said, try everything else before you go with anything abrasive, any kind of sand paper, steel wool, Scotch Brite ect will make the metal in that spot really shiny and I think you would welcome the hand print back, once you disturb the mill finish there is no going back.
It is paint, something will take it off.
cemcrae53
Use goof-off [home depot or lowes] applied with a soft cloth .
Clutzmi
I tried evevrything u guys recommended and it still didnt come off. It did shine the spot up so im going to have to go with somthing abrasive I think
twiggy2cents
Some sort of acid should make it re-oxidize after you are done. Maybe muratic acid will?
BatDaddy1887
....I think it's time to bring in a local Wizard, 'cause it's gonna take magic to get that off!
...or, you could add to it, put the same thing on the other side and that will be your boat's logo....:)
cc350
Bon ami and a buffer!
BatDaddy1887
SHARKHIDE BLACK STREAK REMOVER! Good stuff.
Bamaman1
Acid based cleaners always leave a cloudy oxidation on the toons. If you then go after the toons with aluminum polish, you could have'em looking better than new. It often takes lacquer cleaner, elbow grease and a bunch of rags to get the black oxidation off during/after polishing.
Then, wipe it down with Sharkhide protectant to maintain that mirror shine.
My new Bennington didn't take a month until the toons were tarnishing. I plan on polishing and Sharkhiding them when I pull it for the 20 hour oil change.
