How do I know a prop is Stainless steel
Rick.
Hello All. This is my first post in the prop forum. I found a prop for sale and the Kijiji add says it's new and stainless steel. It is painted black in his picture. I always thought a stainless prop would be unpainted but I don't know that. Is there a way to tell what material it is made of without doing any cosmetic damage to it? Thanks for your help. Rick.
coastalrichard
Re: How do I know a prop is Stainless steel
If a magnet sticks to it, it's stainless. Magnets won't stick to aluminum.
H20Rat
Guess I haven't checked, but most stainless steel is nonmagnetic. SS that has a high nickel/chrome content, as you would want for something that is going to be in the water, is generally non-magnetic.
In other words, if the magnet sticks, it is certainly not aluminum! If it does not stick, it doesn't tell you anything about the prop. Could be aluminum, or non magnetic SS.
Without doing further testing, one way to tell is to look at the blade thickness. SS are usually a little thinner. Also, there should be some model stamps somewhere on the hub which should lead you to what it is.
stainless steel is 2.8 times heavier than aluminum. many stainless props are powder coated because it is cheaper than polishing.
coastalrichard
Well...I grabbed one of the many magnets off the fridge...it doesn't stick to my utility trailer or prop (both aluminum) but it does stick to my gas cap and several other known stainless fittings on the boat.
Smokin, could it be that some grades of stainless have enough steel to remain magnetic while others won't (the boys at the junk yard swear by this method!)?
spdracr39
400 series stainless is magnetic and is used in cheap applications like inexpensive "stainless" gas grills, car trim, restaurant equipment... it has very little nickel content. 300 series stainless is non-magnetic and has a higher nickel content and will last longer, costs more, and is not magnetic. Since I work at a recycling facility I always carry my magnet with me and don't pay extra for the stainless claim unless it is non magnetic.
QC
Best way to verify might be the part number? Agree weight is VERY obvious with Stainless props. Some are unbelievably heavy.
tswiczko
There are 3 types of Stainless Ferritic, Austenitic and Martensitic, and more than one grade of each of the different types.
http://www.mceproducts.com/knowledge-base/article/article-dtl.asp?id=18
spdracr39
If you grind it and it sparks its either stainless or steel of some type. If there is no spark its aluminum or brass. Not a practical test however.
Rick.
Wow. Ask a simple question and....LOL. Certainly appreciate your help. I do have a part number the fellow gave me. it is#386841 which and it is for a 1995-40 HP Johnson. Can you tell from that if it is stainless. I live about 50 miles from the seller so don't want any surprises. Thanks, Rick.
haulnazz15
You would need to know the prop manufacturer most likely. Like Michigan Wheel, Solas, etc.
82rude
if your thinking about going to look at the prop the simple solution is to take your old prop .one in each hand will tell the diff as stainless props are fairly heavy,also lots of people paint their ss props as a anti theft thing.
Brewman61
Ensign
My SS prop (Power Tech) does hold a magnet. It's also way heavier than my AL prop.
colbyt
I don't know the different grades and I for sure have no clue of which a prop is made. Food service grade and my fridge door will not hold a magnet. Some of the lessor metals that pass for SS are magnetically inclined.
jestor68
Older OMC SS props that I purchased back in the day were painted black. The aluminum props were white.
spdracr39
11-3/4 x 17 RH Alum. made by Michigan wheel
http://www.shipstore.com/SS/HTML/mwc/mwc012039.html
Google is our friend
catfishr1
Howdy Rick. S/S props are manufactured by pouring molten stainless into a mold thus 1 fluid piece. If you look at back side of prop you can see seam were blades are attached on aluminum.
Rick.
Well it was aluminum. When I pointed that out to him he said I could have it for 40 dollars so I bought it. It is new, never used and an exact match to the one I had brought with me. Thanks to all who replied. Much appreciated. Rick.
