Greg68S
- Joined
- Feb 18, 2012
- 200
1989 Mercruiser 5.7L V8
Alpha One Out drive
Engine serial
0C664458
Drive serial
0C796105
Transom serial
0C724496
My trim goes up and down normally but under load it won't go. The pump is working normally and my trim fluid I found to be extremely milky in texture. I assume that this is a moisture problem. So how do I know which cylinder is no good? The it will trim under a load under 15 miles an hour, after that the load is to great and won't push it. I have since flushed my fluid and replaced with new.
Thanks guys
-Greg
Alpha One Out drive
Engine serial
0C664458
Drive serial
0C796105
Transom serial
0C724496
Thanks guys
-Greg
