Re: How do i look up the specs on my motor?
Thanks! Wow - I looked up the service manual - $75.00???!!!! Can that be right? It might be cheaper to just by a new engine! The owners manual was $25.00. Will that contain enough info for me to properly maintain the engine?
The owners manual will give you just enough very basic information of "when and how" to maintain your engine with very basic specifications on oil's, greases, and maybe a spark plug gap, But not much more then that.
It does not go into detail really of how to work on the engine or how to change the water pump rubber impeller, Things like that.
Being it's an 1988 engine it might be time to have a service manual like that handy laying around Because you never know when you'll need it.
FYI, Keep in mind that the price of the service manual is either about the same as, or in a lot of cases it's cheaper than one hour's labor at some of the marine service shops.
P.S there are aftermarket service manuals that you can normally buy through places like this website (iboat.com
) at a cheaper price that will work ok, But keep in mind that sometimes you'll get what you pay for.
Hay, if your into the holidays and someone asks you what do you want, Now you know.
Hope this helps, Good luck.
