I took the cam belt and sprocket off my 1979 honda 7.5hp to change the points! what marks do I line up to get the timeing back on? I see the mark on the cam sprocket, motor block and the mark's on the flywheel (T&F) Thanks for the help:<br />Rodney
Re: How do I put the cam back in time on my 7.5HP Honda?
Easy. Remove the pull starter and on the back boss that that starter bolted to you will see a line. Turn yor flywheel until the T mark on it lines up with that mark.That's TDC.Now turn the cam until the dot on the pulley lines up with the similar looking dot stamped into the cylinder head and you've got it.
