Re: How do I remove a distributor rotor on 5.7 Mercruiser motor
I want to remove the distributor sensor on a 5.7 Mercruiser. I have tested it and it showed it is open. No resistance. The engine starts and dies in 10 -60seconds. I can't remove the rotor. Please help! Ted
In your title you say rotor, in the post you say sensor. Which is it????
Mercruiser has used 5.7 engines since 1969. They are different in many ways from what we have in 2009.
So how about some info. Model numbers, serial numbers, year, ignition type, mechanical or electric fuel pump, etc. etc. ............
