Re: how do I remove my motor
thank you very much just what I needed to hear, lots of big trees on the west coast of BC. thanks again guys
I think it goes with out saying, but I'm gunna say the obvious; Be careful using a tree!
If you want to be smart about it, rather than using a branch, you can build a boom system using the tree as an upright.
My buddy did this with a BIG tree in his yard. He got a long 4X10 beam, and attached it to the bottom of the tree with a bracket system that would allow the top of the beam to pivot away from the tree (like a crane boom). He then attached a strap from the middle of the beam to the side of the tree, so he could swing the boom to and from the tree. He then put a LARGE cap screw at the end of the beam that he could attach his rigging to (10000 LB lift strap, and a chain fall). Worked like a charm. Wish I had pictures.
